Removes an MPLS interface from the specified VLAN.
| vlan_name | Identifies the VLAN for which the MPLS interface is deleted. |
| vlan all | Deletes the MPLS interface from all VLANS that have MPLS configured. |
VLANs are not configured with an MPLS interface.
An MPLS interface must be configured on a VLAN in order to transmit or receive MPLS packets on that interface. If the MPLS interface is deleted, all configuration information associated with the MPLS interface is lost. Issuing this command brings down all LDP neighbor sessions and all LSPs that are established through the specified VLAN interface. When the all VLANs option is selected, the MPLS interface for all MPLS configured VLANs is deleted.
The following example deletes MPLS from the VLAN vlan_k:
configure mpls delete vlan vlan_k
This command was first available in ExtremeXOS 11.6
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
